Laguna Revo 18|36 & 24|36 Lathe Cast Leg Support
111794
From £309.98 £258.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Provides exceptional stability, reducing vibrations for precise work
  • Enhances accuracy by maintaining a secure and steady lathe position
  • Made from durable cast iron for long-lasting support
  • Easy to install, integrating seamlessly into your workshop setup
Upgrade your Laguna Revo 18|36 and 24|36 lathes with the Laguna Cast Leg Support, designed to provide unparalleled stability and support for your woodworking projects. This accessory is crafted from high-quality cast iron, ensuring a robust and durable foundation that minimizes vibrations and enhances precision.
The Laguna Cast Leg Support significantly improves the overall stability of your lathe, allowing you to work with confidence on even the most intricate and detailed pieces. By reducing vibrations, it helps maintain the accuracy of your cuts and finishes, resulting in superior craftsmanship. Additionally, the sturdy construction of the cast leg support ensures that your lathe remains securely in place, even during heavy-duty operations.
Installation is straightforward, allowing you to quickly integrate this essential accessory into your workshop setup. Once installed, you’ll immediately notice the difference in the performance and reliability of your lathe. The sleek design of the cast leg support also complements the aesthetic of your Laguna lathe, making it a seamless addition to your workspace.
Enhance your woodworking experience with the Laguna Cast Leg Support and enjoy the benefits of increased stability, precision, and durability in all your projects.
