Laguna Revo 18|36 & 24|36 Lathe Swing Away Extension
111792
From £240.98 £200.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Allows the tailstock to easily be moved out of the way.
  • Provides unobstructed access to your workpiece.
  • Enhances a lathe’s functionality, making intricate tasks easier.
  • Built with durable materials, ensuring long-lasting performance.
  • Installation is simple and quick.
Elevate your woodworking experience with the Laguna Swing Away Extension for the Laguna Revo 18|36 and 24|36 Lathes. This innovative accessory is designed to enhance your lathe’s functionality by allowing the tailstock to swing out of the way effortlessly.
Imagine the convenience of having unobstructed access to your workpiece, making it easier to perform intricate tasks and adjustments. The Swing Away Extension provides this benefit, ensuring that you can work more efficiently and comfortably. No more struggling with limited space or awkward angles; simply swing the tailstock away when it’s not needed and bring it back into position when it is.
Crafted with the same high standards as your Laguna lathe, this extension is built to last. Its robust construction ensures durability and reliability, even under heavy use. Installation is straightforward and includes hinge and lock-handle and does not require any drilling, allowing you to quickly integrate it into your lathe setup and start enjoying the benefits immediately.
Upgrade your lathe with the Laguna Swing Away Extension and experience the freedom and flexibility it brings to your woodworking projects.
