Lamello Bisco Biscuits
- Flat plastic aligning/ connecting biscuit
- Gives added shear strength
- 7mm thick plastic biscuit, can be glued if required
- For slot produced by P system Zeta or CNC groove
- P-14 size 65mm x 27mm
- P-10 size 52mm x 19mm
Lamello P-System Professional Connector Assortment In Sortainer CaseFrom £699.98 £583.32
Used as as an aligning or jointing biscuit, the 7mm thick flat Bisco is designed to work with the P-system groove produced by the Zeta or CNC system, providing alignment for assembly and greater shear strength, it can be glued in place if required. The
Bisco is a flat 7mm plastic biscuit and is available in two sizes.
Bisco P-14 is 65mm x 27mm or Bisco P-10 is 52mm x 19mm
