Co-Matic TK 65 Dual End Cutter
505082
From £72.18 £60.15
  3. Empty Star
  4. Empty Star
1 Review
Low Stock - Ready to dispatch
  • The perfect tool for cutting edgebands or edge tape
  • Designed for both professional and hobby use
  • Makes aligned cuts without the need for changing any components
  • Unique two-point support design ensures perfectly connected, aligned cuts
  • It can handle material up to 3mm thick and 62mm wide
  • The ergonomic handle make use a pleasure
The TK 65 Dual End Cutter is the perfect tool for cutting edgebands or edge tape. Designed for both professional and hobby use, this end cutter makes aligned cuts without the need for changing any components or using any additional guides. It has a unique two-point support design to ensure perfectly connected and aligned cuts. It can handle material up to 3mm thick and 62mm wide, whilst the ergonomic handle makes it a pleasure to use.
2.00 1
