Mafell Aerofix F-AF 1 Suction Rail Guide Track
108499
From £214.98 £179.15
Low Stock
  • Unique guide rail eliminates slippage in use
  • Uses extractor’s vacuum to form a secure connection
  • Suction prevents rail movement during cuts
The Aerofix F-AF 1 guide rail uses the vacuum produced by your dust extractor to form a secure connection to your workpiece. Used with Mafell guided saws and other compatible tools, the suction created prevents movement during cuts. The vacuum adapter can be connected to the top or bottom of the guide rail to suit the work in hand. The vacuum adaptor connects both the Aerofix guide rail adapter and your saw, providing dust extraction during the cut.
Mafell's unique Aerofix F-AF 1 guide rail is 1,300mm overall with a cutting length of 1,100mm. The Aerofix system can be extended using Mafell guide rails (F 160, F 110, F 80) and a connector.
The Aerofix suction track also fits the Bosch GKT55 plunge saw.
Larger Mafell saws (MKS 130Ec, MKS 165 Ec, MKS 185 Ec and ZSX TWIN Ec) require a 58/35mm Reducing Socket.
Cutting depth is reduced by 5.5mm when using the rail.
Saw blade will remove a portion of the rubber splinter guard on the first cut, calibrating the rubber exactly to your blade’s kerf.
Kit includes:
1 x Mafell F-AF1 Aero Fix Guide Track Suction Clamping System
1 x 1.300mm rail
2 x Adaptors
1 x Hose
Compatible with the following tools:
DSS 300 cc Insulation saw
K 65 18M bl Cordless Portable Circular Saw
K 65 cc Portable Circular Saw
K 85 Ec Portable Circular Saw
KSS 300 Cross-Cutting System
KSS 40 18M bl Cordless Cross-Cutting System
KSS 400 Cross-Cutting System
KSS 50 18M bl Cordless Cross-Cutting System
KSS 50 cc Cross-Cutting System
KSS 60 18M bl Cordless Cross-Cutting System
KSS 60 cc Cross-Cutting System
KSS 80 Ec Cross-Cutting System
KSS 80 Ec/370 Cross-Cutting System
LO 65 Ec Hand Router
MF26 cc/400 Multi-Cutter
MKS 130 Ec Circular Saw
MKS 145 Ec Circular Saw
MKS 165 Ec Circular Saw
MKS 185 Ec Circular Saw
MS 55 Circular Saw
MT 55 18M bl Cordless Plunge/Track Saw
MT 55 cc Plunge/Track Saw
NFU 50 Groove-Cutting Machine
P1 cc Jigsaw
ZSX Ec / 400 HM Carpenter's Chain Saw
ZSX Ec Carpenter's Chain Saw
5 1
