Dowel joints have long been recognised as a strong and accurate way of constructing cabinets. The Mafell Duo-Dowel DDF 40 offers a high level of accuracy and efficiency in a dedicated, easy to use power tool.
Compared to other jointing machines the DDF 40 makes great economic sense, as long term there are significant savings by using standard wooden dowels compared to other more expensive alternatives.
The machine drills pairs of dowel holes at 32mm centres. It features fully adjustable fences for positioning against a reference edge. The DDF 40 can produce edge, corner and mitre joints and be used to drill a row of holes at 32mm centres. For anyone making, building or fitting System 32 cabinetry, this is an invaluable machine. It is an ideal tool for those involved in bespoke cabinets or frequently need to build adaptations. The DDF 40 gives you the precision of a stationary machine in a hand held power tool for use in the workshop or on site.
The DDF40 Duo is supplied in a Mafell T-MAX1 case with a range of accessories including 2x 6mm HW dowel drills, 2x 8mm HW dowel drills, 1x auxiliary rest (ZA), 1x set of additional stops (ZAG), 1x hose connector, 1x position indicator (PAZ), 1x side fence set (SA) 320, 1x stop pin insert for battens (LA), 2x Anti-slip mats, 1x 250ml Glue Bottle with 8mm Nozzle, 350x 6mm wooden dowels and 200x 8mm wooden dowels. Many other additional, optional accessories are available such as an 80mm template guide
