The Mafell LS 103 Ec Chain Morticer has a 2,500W powerful motor for rapid progress through the timber. There is plenty of power here to cut into green oak with ease. Its ergonomic handle and switch arrangement offer safe, efficient, energy-saving working. Weighing in at only 8.7kg makes it easier to handle in site working situations.
The LS 105 Ec comes with a long guide plate with a large adjusting range, permitting work on large timber workpieces. The standard chain cuts a mortice 40mm wide by 28mm long and up to 150mm deep. Simply move the machine along for repeat cuts to extend the length of the mortice. The LS 103 Ec is ideal for precise framing work.
Initial assembly is very straightforward, in no time at all you’ll be up and running. The tensioning system of the LS 103 Ec allows fast chain replacement. Even retightening of the chain without removing the chain guard is quick and easy. The machine comes with a 10m long heavy duty cable, so there should be little need for extension leads even when on site.
This is a great value product, very well built as you would expect from Mafell, it performs beautifully and very accurately.
Mafell LS 103 Ec guide support stand if an ideal optional extra (sold separately), to add extra precision to your framing work.
No Load Speed: 4,050rpm
