Mafell ZH 205 Ec Carpenter's Beam Planer - 230V
108172
From £3,049.98 £2,541.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Plane 208mm wide timbers with ease
  • Stepless planing depth adjustment up to 4mm
  • Easy-to-change reversible blades
The Mafell ZH 205 Ec beam planer with its 208mm planing width means you can plane large timbers with ease. It is well worth serious consideration from timber framers, carpenters, boat builders etc.
The front knob offers stepless planing depth adjustment up to 4mm. These impressive specifications are made possible by the 2,300W high efficiency motor running at 8,500rpm. Intelligent control electronics monitor performance ensuring constant speed under load. The electronics give you smooth start up and overload protection.
This is a solidly built machine designed for practical use and ease of handling. It features a large comfort grip front handle and weighs in at a manageable 12.5kg. The 10m power cord allows long passes without resorting to extension leads.
The chip ejector features enhanced air flow and through an air duct. The removal of large amounts of material never becomes a problem, even when planing unseasoned timbers. A special base plate structure ensures smooth movement and a ball bearing roller guide can be used to keep the machine on track by following an edge.
Easy-to-change reversible blades are a great aid to high productivity, no more time-consuming blade adjustments.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
