With the Mafell ZH 320 Ec beam planer with its 320mm planing width means you can plane large timbers with ease. It is well worth serious consideration from timber framers, carpenters, boat builders etc.
The front knob offers stepless planing, depth adjustment up to 3mm. These impressive specifications are made possible by the 2,700W high efficiency motor running at 8,500rpm. Intelligent control electronics monitor performance ensuring constant speed under load. The electronics give you smooth start up and overload protection.
This is a solidly built machine designed for practical use and ease of handling. It features a large comfort grip front handle and weighs in at a manageable 14kg. The 10m power cord allows long passes without restoring to extension leads.
The chip ejector features enhanced air flow and through an air duct. The removal of large amounts of material never becomes a problem, even when planing unseasoned timbers. A special base plate structure ensures smooth movement and a ball bearing roller guide can be used to keep the machine on track by following an edge.
Easy to change reversible blades are a great aid to high productivity, no more time consuming blade adjustments.
