Makita DJR186Z Cordless Sabre Saw 18V (Body Only)
- Multi-purpose, multi-cutting saw for wood, metal, plastic etc
- Tool-less blade change, simple locking mechanism
- Variable speed trigger switch with lock-off lever
- Maximum cut in wood of 255mm with 2,900 strokes per minute
- Ergonomically designed handle for safe and comfortable grip
- High efficiency crank mechanism
- Body only supplied without battery or charger
Model DJR186 is a cordless sabre or reciprocating saw. This version is body only and requires power from a Makita slide-on LXT 18V Li-ion battery. The design offers you high cutting efficiency and more durability. A sabre or reciprocating saw is an extremely useful tool. The DJR features tool-less blade change. It has a variable speed trigger and an electric brake, giving you complete control. The soft grip handle with an anti-slip elastomer wrap offers comfort and helps minimise vibration. With the wide variety of blade types available, you can cut wood, metal and plastic. With the right blade, it is possible to cut mild steel pipe, railway sleepers or pruning trees.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Corded or Cordless | Cordless |
EAN Barcode | 0088381806640 |
Max Cutting Diameter Pipe | 130 mm |
Max Depth of Cut Wood | 255 mm |
Model | DJR186Z |
Nett Weight | 3.8 kg |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Stroke Length | 32 mm |
Stroke Rate | 0 - 2,800 /min |
Vibration Cutting Wood [Uncertainty K] | 12.5 m/s² [1.5 m/s²] |
