Makita DRT50ZJX3 Trimmer KIT in Makpac Case 18V (Body Only)
104401
From £309.98 £258.32
Low Stock
  • Complete kit with 4 different base options
  • Ideal for trimming and cabinet routing operations
  • Brushless motor for long battery runtimes
  • Soft start with variable speed control
  • Constant speed control under load
  • Shaft lock for easy installation of cutters
  • LED job light for improved visibility
  • Supplied with 4 bases (trimming, plunge, tilt and offset) 1/4" collet, 2 guides (trimming and straight), 2 dust extraction adaptors (trimming & plunge), 2 template guides (trimming & plunge), auxiliary handles, guide holder and wrenches and Makpac storage case (type 4)
The Makita DRT50ZJX3 cordless router trimmer kit includes all you need for trimming and light routing operations. The brushless motor is maintenance free throughout its life and gives long battery runtimes. Designed without carbon brushes, these motors run cooler and far more efficiently, resulting in a long trouble free working life.
The DRT50ZJX3 motor unit has a solid construction and aluminium housing for high durability and accuracy. The soft-start feature prevents any initial jolt and the constant speed control maintains the speed under load. A variable speed dial allows you to choose the speed from 10,000 to 30,000 rpm. It is compatible with any of the Makita 18V LXT batteries up to 6.0Ah.
Other features include an LED job light to illuminate the work area, push button on/off switch with an on/off safety button to prevent unintentional start-up. A shaft lock makes changing cutters straightforward.
This body only version comes with 4 bases: Plunge, Trimmer, Tilting and Offset.
The Trimmer base has a non-slip, elastomer body grip for control and comfort. Depth adjustment is precise and simple. A non-marking base plate protects the work surface and helps the trimmer glide smoothly.
The Plunge offers a plunging depth of up to 35mm and has a 3-stage depth stop. The locking lever is easily accessible and the handles have a rubberised soft grip for increased grip.
The Offset base provides the ability to trim close to walls and with the bit set in offset position. The elastomer covered body grip for increases comfort and control.
The Tilting base angles from minus 30° to plus 45°. The enlarged open section greatly improves visibility of the cutter. The base features an ergonomic body grip and replaceable baseplate.
In addition the DRT50ZJX3 comes with 1/4" collet, 2 guides (trimmer and straight), 2 dust extraction adaptors (trimmer and plunge bases), 2 template guides (trimmer and plunge bases), auxiliary handles, side fence and wrenches. All this contained in a Makpac storage case (type 4).
Warranty Makita 3 Year Warranty (Registration Required)
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
  • Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
  • The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.80 12
