The Makita LS1019L dual-bevel sliding compound mitre saw combines capacity, accuracy and efficient dust extraction with a reduced footprint.
Its unique twin slide rails allow you to operate it flush against a wall. Rather than requiring space at the rear to accommodate the rails, the LS1019L fits perfectly on a workbench against a wall or confined spaces when working on site.
Power comes from a 1,510W direct drive motor with soft start. Electronic speed control maintains constant speed under load for smooth, high quality cuts. An electric brake brings the blade to an almost immediate halt on releasing the trigger. The angle of the motor mounting is one of the reasons this saw has a comparably larger capacity. The saw can cut mitres from 0° to 60° both left and right, with indexed stops at 0°, 15°, 22.5°, 31.6°, 45° and 60° (left or right). The bevelling capacity is from 0° to 48° both left and right. The bevel locking mechanism is conveniently located in the front of the saw giving you easy access for quick adjustments.
The built-in laser indicates the cutline and is adjustable to indicate the left or right side of the cutline whichever you prefer. The translucent blade guard gives better visibility of the blade when positioning the work.
A large, flexible dust collection port behind the blade helps provide effective extraction. The LS1019L includes a dust bag and a hose to connect to a vacuum extraction point. The saw’s large aluminium base features additional pull-out supports for more stable cutting.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
