Matsui PICO Scriber Gauge
108814
From £68.98 £57.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Perfect parallel edges accurate to 0.1mm
  • Precision and repeatable precision
  • Measuring or scribing depth max. 100mm
  • For woodwork, metal work layout operations.
  • Hardened SUS420J2 stainless steel
  • Size: L170mm x W51mm, weight: 90g
  • Made in Japan
The PICO gauge has its origins in engineering and machining. When it comes to woodwork this small marking gauge offers you unparalleled accuracy (pun intended).
The PICO gauge is designed to be a small, handy marking and measuring device, easily taken to the work.
Its main function is similar to that of a combination square, but with far greater precision and repeatable precision. The PICO gauge can be set to an accuracy of 0.1mm. This tool will give you a perfect parallel edge when measuring and marking. The reference bar is 50mm long by 3.8mm deep for maximum support. You can use it with items of various shapes, including parallel, vertical, cylindrical, objects with rounded corners, etc.
Suitable for woodworking, metal work and all manner of layout operations.
Measuring or scribing depth max. 100mm with 0.1mm vernier scale. The back of the gauge has a 50mm scale for use as a depth gauge. Made of hardened SUS420J2 stainless steel for long life and corrosion resistance.
Size: approx L170mm x W51mm
Weight: approx. 90g
Made in Japan.
