Metabo KGS216M Slide Mitre Saw 216mm 230V
- Suitable for the home workshop
- For sawing wood, coated panels, plastic
- Achieve precision cuts with ease.
- Adjustable table extension and integrated crosscut fence
- Easy to transport
- Integrated work light for poorly lit areas
- Non slip rubber handle and two lateral handles
The Metabo KGS216M Sliding Mitre Saw is a reliable choice for home workshop use that can handle a variety of uses at good value for money.
A strong die-cast aluminium workbench and sliding function allow for wide work pieces; it is ideal for sawing wood, coated panels, and plastics with ease and precision. The saw features a freely adjustable table extension on both sides for a practical support surface and integrated crosscut fence, creating an easy-to-use work area.
Ensuring the saw is comfortable and safety is the priority, the handle features a non-slip rubber grip, as well as lateral handles for easy transport, a transport lock and a cable winder. An integrated work light is fitted for use in poorly lit areas.
All scales are visible, and the turntable allows for precise angle adjustment, making it easier to achieve precision cuts. As well as an integrated cutting depth control, handy for achieving a variety of cuts.
Supplied with 1 x 40 Tooth Carbide Saw Blade, 2 x Table Leg Extensions, Length Guide, Material Clamp Tool for Saw Blade Change, Dust Chip Collection Bag.
