Mirka Abranet Abrasive Sheets 80 x 230mm (Pkt10)
- An incredibly efficient long lasting abrasive
- Open mesh design eliminates clogging
- Compatible with the Mirka sanding block
- 80 x 230mm abrasive with hook and loop backing
Abranet® is a revolutionary abrasive material offering dust free sanding with no clogging. The open mesh design with hook and loop backing features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet® abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra-smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These abrasives are suitable for a wide range of materials including the decorating, woodworking and automotive industries and are compatible with the handy Mirka sanding block.
Abrasive Backing | Mesh and Hook and loop |
Abrasive Sheet Size | 80 mm x 230 mm |
Abrasive Type | Abranet |
