Mirka DEROS II 5650CV Solution Kit with 150 Abranet
111676
Special Price £547.98 £456.65 was £576.98 £480.82 Save £29.00 £24.17
3 Reviews
Low Stock - Ready to dispatch
  • Unique 400W high performance brushless motor
  • 5mm orbit for fast material removal
  • Supplied with both 125mm and 150mm pads
  • LED speed indicators to easily adjust variable sanding speed
  • Low profile with low weight, easy to use in any position
  • Soft start and electronic brake for controlled sanding
  • Bluetooth technology for monitoring vibration levels
  • Supplied in T-LOC storage case
  • 2+1 Extended Warranty on sanders, registration required
The DEROS II 5650CV is supplied with both 125mm and 150mm pads for greater versatility. It is one of the most compact random orbit sanders on the market today. With its ergonomic design and low weight (only 1kg), it is perfect for all prolonged use in almost any position - flat, overhead or vertical.
The sander features upgraded power compared to previous models; the body of the machine houses a 400W high performance, smooth running brushless motor for increased service life, and maintains constant speed even under load. The DEROS II 5650CV is fitted with a soft start and electronic brake. The sanding speed is adjustable, with the range covering 4,000 - 10,000rpm. The updated design makes it easy for the operator to change the speed; LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control. The DEROS II 5650CV has a closed construction so that no dust can enter the machine. One of the key features of the Mirka DEROS II is the enhanced Bluetooth low energy technology, which allows you to monitor vibration levels, in real-time on a smartphone or tablet via the myMirka app.
The 125mm and 150mm backing pads can be exchanged quickly to suit your application; both pads have a universal hole pattern to enable the fitting of many different makes and types of abrasive disc.
The DEROS II 5650CV comes in a T-LOC storage case along with 150 Abranet discs (150mm diameter, 80 to 180 grit).
The Deco solutions kit contains:
50 x Abranet® 150mm sheets grit P80
50 x Abranet® 150mm sheets grit P120
50 x Abranet® 150mm sheets grit P180
Warranty Mirka 3 Year Warranty (Registration Required)
Registration is required within 30 days of purchase.
The Mirka 2+1 year warranty applies to Mirka sanders, dust extractors and polishers. If a problem occurs with a Mirka tool caused by a manufacturing defect material or by workmanship; Mirka will repair your tool free of charge in accordance with the warranty terms.
Registration is required within 30 days of purchase. More information can be found on the Mirka warranty website and in the warranty conditions.
For warranty issues outside of the UK, tools must be returned to the UK and carriage charges would be at the customer's own cost.
Register your product now
5.00 3
