Mirka Double-Sided Sanding Sponge (Pkt 20)
- Silicon Carbide grain: hard wearing stays sharp longer
- Low-density foam: conforms to curved surfaces
- Enables a premium finish on profiled or flat surfaces
- Size: 98 x 120 x 13mm
Silicon carbide grain coated onto two sides of low-density foam to enable a premium finish on profiled or flat surfaces. Used wet or dry, they are excellent for preparation of surfaces prior to re-coating. Choose from a mixed pack comprising 10x 180 and 10x 220 grit or a pack of 20x 220 grit. Each sanding sponge measures approx 98 x 120 x 13mm.
Abrasive Backing | Foam |
Abrasive Material | Silicon Carbide |
