Mirka Interface Pad 125mm 33 Hole
- 33-hole interface pad suitable for the Mirka DEROS
- 10mm thick, invaluable for use on rounded surfaces and contours
- Helps produce a softer result and improved finish
Mirka Abranet Abrasive Discs 125mm (Pkt 10) - 120gSpecial Price £9.25 £7.71 was £10.28 £8.57 Save £1.03 £0.86
Mirka Abranet Abrasive Discs 125mm (Pkt 50) - 320gSpecial Price £35.62 £29.68 was £39.58 £32.98 Save £3.96 £3.30
This 33-hole interface pad is suitable for the Mirka DEROS sander. 10mm thick, the pad fits between the baseplate of the sanding machine and the sanding disc. This is invaluable when sanding rounded surfaces and contours. The interface pad stabilises the sanding process and will also help produce a softer result.
EAN Barcode | 6416868913040 |
