Mirka Interface Pads for Sanding Blocks
- Features hook and loop backed interface pads for contour sanding
- Fits between sanding pad and abrasive
- Minimises wear to your backing pad
The thick foam cushion of these Mirka hook and loop backed interface pads will allow better sanding of contoured surfaces and will also help to extend the life of the backing pad on your sanding block. Fitted between the sanding pad and the abrasive, simply peel off and discard if they eventually become worn. Available as singles, size of 70 x 125mm.
EAN Barcode | 6416868944259 |
Overall L x W x H | 70 x 125mm |
