N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
For fine detailed cuts in wood, plastic or foam
Compatible with all No. 2 and No. 5 knife handles
Blade tapers from 1mm to 4mm, overall 60mm long with 24tpi
These ModelCraft keyhole saw blades fit perfectly in the Model Craft No. 2 knife handle and the Modelcraft 8 piece saw set. They are compatible with the No. 2 and No. 5 plastic handles from other manufacturers. These 60mm long blades have 24tpi for exceptionally fine cuts. When fitted into the knife handle, you can make delicate cuts in balsa, softwood, cardboard, plastic or foam. The blade tapers from 1mm at the tip to 4mm at its widest.
