Pegas Metal Cutting Scroll Saw Blades
AX877557
AX877557
- Use in scroll saws or hand frames
- For precise cutting of thin metals up to 3mm
- Made in Switzerland
- Blade length 130mm
- Packs of 12
Show more
Show less
These are high quality blades for precise cutting of thin metals up to 3mm (1/8") thick and for other hard, non-metallic materials. They are specifically heat treated to give maximum performance with power scroll saws. These blades are suitable for use in handheld fret and piercing saw frames. Swiss made, Pégas® scroll saw blades use only the best available carbon steels. Overall blade length 130mm.
Scroll Saw Blade Length | 130 mm |
