Pigtail Mop Arbor 6mm Shank
- Enables mops to be used in a power drill or flexible shaft
- For use with leather centred mops
- 6mm shank
- Recommended mops no more than 100mm diameter
This pigtail arbor enables a leather centred polishing mop to be mounted in a power drill or flexible shaft. It has a 6mm shank to fit into the drill's chuck. Please note, when using a polishing mop in a drill or flexible shaft, it is recommended to use mops no more than 100mm in diameter.
EAN Barcode | 5060030665995 |
