PROXXON 36 Piece Precision Engineer's Socket Set (1/4")
- 13 sockets from 4mm to 13mm
- Industrial quality ratchet, with high level of torque
- 1/4" square drive screwdriver handle plus accessories
- Powder coated steel box
The PROXXON 1/4" square drive socket set with 36 pieces for Precision Engineers. The 13 sockets cover the range from 4 to 13 mm. The design of the industrial quality ratchet has been tried and tested 100,000 times to a high level of torque so quality is assured. Twelve screwdriver inserts with 1/4" square drive are included, covering for slotted, Philips, Torx and Hex headed screws. The set includes a 1/4" square drive screwdriver handle, two extensions, a universal joint and a T-adaptor. There are also five hex keys 1.25, 1.5, 2.0, 2.5 and 3mm, all supplied in a robust powder coated steel box.
Drive | 1/4" Square Drive |
EAN Barcode | 4006274230804 |
