PROXXON 39 Piece Screwdriver and Socket Set (1/4")
- Supplied in robust powder coated steel box
- Industrial quality designed for professional use
- Comprehensive 1/4" drive socket and bit set
The PROXXON (23070) 39-piece 1/4" square drive screwdriver and socket set, contains both sockets and screwdriver tips to cover a host of tasks.
1/4" Sq drive ratchet
12 Sockets: 4, 5, 6, 6.5, 7, 8, 9, 10, 11, 12, 13 & 14mm
1 Bit holder socket 1/4"
16 Bits:
Hex 3, 4, 5 & 6mm
Philips: Ph1, 2 & 3
Slotted 3.5, 4, 5.5 & 6.5mm
Torx T8, T10, T15, T20, T25 & T30
1 Socket adaptor 1/4"
1 Extension 100 mm
1 Screwdriver handle with square drive 1/4"
1 Magnetic holder with hexagon shank 1/4"
5 Allen keys: 1.25, 1.5, 2, 2.5 & 3mm
Drive | 1/4" Square Drive |
EAN Barcode | 4006274230705 |
