PROXXON Battery-Powered Belt Sander BS/A (Body Only)
- Perfect for intricate jobs, delicate finishing or refining
- 10mm wide sanding belt, 110mm arm length
- Head angle changed at the touch of a button
- Die-cast aluminium head ensures long, trouble-free working life
- Comfort grip for greater control
- Body only tool supplied without batteries and charger
This quality, cordless industrial power tool is ideal for the grinding of small openings, finishing of moulds, surfaces, radii, grooving, deburring and chamfering of precision parts. You can change the angle between the head and the body at the touch of a button by 60° for better access. Changing the sanding belt takes only a few seconds. The BS/A has a vacuum connection for clean working. This professional quality battery-powered MICROMOT tool combines the features of the mains equivalent with the convenience of a cordless tool. The main bearings and gears sit in a die-cast aluminium head ensuring a long, trouble-free working life. The glass fibre reinforced POLYAMIDE main body houses a special balanced, powerful, quiet and long lasting DC motor. The soft component body grip offers comfort and greater control. Belt size 10 x 330mm. This is a body only tool supplied without batteries or charger.
Abrasive Belt Size | 10 mm x 330 mm |
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 10.8 V |
Belt Speed | 200 to 700 m/min |
Corded or Cordless | Cordless |
EAN Barcode | 4006274298125 |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 103 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
