PROXXON Diamond Cutting Discs
AX801351
AX801351
- Cuts marble, brick, plaster
- Diamond coated edge
- 20mm or 38mm diameter
Show more
Show less
For cutting marble, brick, plaster and many other materials in the sanitary and electrical fields. Only 0.6mm kerf, with two diameters available either 20mm or 38mm, both mount on a 2.35mm diameter arbor.
#AxminsterTools
