PROXXON EL/A Cordless Soldering Iron - 3.6V (2.0Ah)
109495
109495
- Electronically controlled temperature (470°)
- Integral rechargeable 3.6V battery
- 2.0Ah capacity for long run times
- LED light illuminates the working area
Show more
Show less
This lightweight, electronically controlled temperature (470°) soldering iron frees you from the constraints of a mains lead. Powered by an integral rechargeable 3.6V battery with an impressive 2.0Ah capacity for a long run time. The EL/A features a short heat-up time and an LED light which illuminates the working area. Supplied with protective cover, solder and charging lead (requires a USB to 3pin plug).
Weight 120g.
Batteries Included | Integral |
Battery Capacity | 2.0 Ah |
Battery Type | Li-ion |
Battery Voltage | 3.6 V |
EAN Barcode | 4006274281424 |
Model | EL/A |
