PROXXON FBS 240/E Multi-Tool & Flexi Shaft - PACKAGE DEAL
718858
From £99.98 £83.32
9 Reviews
  • PROXXON FBS 240/E Precision Drill/Grinder Multi -Tool
  • Multiple uses; cuts, sands, polishes and grinds, etc.
  • 0.3-3.2mm keyless chuck
  • Variable speed
  • Two inset rubber body grips
  • Permanent magnet motor
  • Maximum motor power 100W
  • Supplied in a plastic storage case
  • 43 cutting, grinding, drilling and sanding accessories
  • PROXXON 110/P Flexi-Shaft
  • 1,000mm flexible shaft
  • Six steel collets - 1mm to 3.2mm
  • Show More
Package deal comprises the PROXXON FBS 240/E Precision Drill/Grinder Multi -Tool and the PROXXON 110/P Flexi-Shaft.
PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool
This 100W Multi-Tool has a keyless chuck (0.3-3.2mm) to accept a wide range of accessories, well balanced and with variable speed for maximum control. The tool is well designed and the two inset rubber grips on the body ensure a good purchase, important for fine detail work. The permanent magnet motor is powerful and well balanced and the variable speed control gives a range of 5,000 to 20,000rpm. At the opposite end to the drill chuck is a hanging loop, used when the tool is coupled up to a flexible shaft. This tool has a quality specification, a flexible drive shaft with precision handpiece and 1.0mm, 2.4mm and 3.0mm collets is also available as an optional extra. Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories.
A truly flexible shaft some 1 metre long with delicate hand piece complete with six steel collets (ranging from 1mm to 3.2mm) for accurate holding of rotary tools and collet nut. Suitable for use with any of the PROXXON range of tools or indeed any type of power source that can grip the 3mm male shaft of the unit.
4.80 9
