PROXXON FBS 240/E Precision Drill/Grinder Multi-Tool
- Multiple uses; cuts, sands, polishes and grinds, etc.
- 0.3-3.2mm keyless chuck
- Variable speed
- 2 inset rubber body grips
- Permanent magnet motor
- Maximum motor power 100W
- Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories
The PROXXON FSB240/E is perfect for jewellers, mechanics, model builders, opticians, electronic enthusiasts and professionals. Can be used for prolonged periods when drilling, milling, die grinding, polishing, cleaning and engraving. This 100W multi-tool has a keyless chuck (0.3-3.2mm) to accept a wide range of accessories, well balanced and with variable speed for maximum control. The tool is well designed and the two inset rubber grips on the body ensure a good purchase, important for fine detail work. The permanent magnet motor is powerful and well balanced and the variable speed control gives a range of 5,000 to 20,000rpm. At the opposite end to the drill chuck is a hanging loop, used when the tool is coupled up to a flexible shaft. This tool has a quality specification, a flexible drive shaft with precision handpiece and 1.0mm, 2.4mm and 3.0mm collets is also available as an optional extra. Supplied in a plastic storage case with 43 cutting, grinding, drilling and sanding accessories.
