PROXXON FF 250/BL MICRO Mill
109490
From £1,061.88 £884.90
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Variable speed pre-selection from 400 - 6.000rpm
  • Solid plane-milled steel compound table with 3 T-slots
  • Digital speed indication
  • Tool holder uses ER 16 (DIN ISO 15488) collets
  • Supplied with 6mm, 8mm and 10mm collets
The FF 250/BL is a stand alone mill/drill, and a high quality addition to the PROXXON Micromot range of engineering machines. The FF 250/BL features variable speed pre-selection from 400 - 6.000rpm with digital speed display. Speed sensors guarantee high torque also in the lower speed range. A rotational speed chart on the front of the housing shows the appropriate spindle speeds for the most common applications. The headstock swivels through 360°, and tilts 90° left and right. The mill/drill’s table offers X-Y travel, longitudinally and cross-wise respectively of 110 x 70mm, with 3 T-slots. The tool holder uses ER 16 collets.
The FF 250/BL is supplied with 6mm, 8mm and 10mm collets.
Warranty PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
