PROXXON Flexible Sanding Pads for WP/A,WP/E - 50mm 1,000g (Pkt 6)
109496
109496
- 50mm diameter hook and loop backed abrasive discs
- 6mm thick soft foam cushion with silicon carbide abrasive
- Net structure helps prevent clogging, longer lasting
- Discs able to conform to any slight curvature
- Supplied in a pack of 6 discs
PROXXON Battery Powered Angle Polisher WP/A (Body Only)From £119.48 £99.57
Show more
Show less
These hook and loop backed 50mm diameter abrasive discs have a 6mm thick soft foam cushion. This cushion allows the abrasive to adapt precisely to any slight curvature of the worked surface. The silicon carbide abrasive is long lasting due to a net structure, which helps prevent clogging. These pads are designed for fine sanding and are especially useful for small automotive repairs or restoration. Supplied in a pack of 6 discs.
EAN Barcode | 4006274286726 |
