PROXXON IBS/E Professional Drill/Grinder
300121
From £94.98 £79.15
26 Reviews
In Stock - Ready to dispatch
  • Very precise and accurate
  • Aluminium motor casing
  • Variable speed (5,000-20,000rpm)
  • Supplied in carrying case with 30 accessories
  • Six collets from 0.8mm to 3.2mm
Perfectly precise with PROXXON
- The 20mm Collar System
The 20mm collar range of PROXXON tools allows you to easily connect to one another and achieve maximum precision and versatility with your intricate tasks. Simply clamp the collar of your PROXXON drill or grinder to the drill stand, universal holder or router base and your tool is held steady whilst allowing you to take on a range of tasks including routing, engraving and drilling.
PROXXON Micromot Mb 200 Drill Stand
Enables bevelled drilling and versatile milling operations.
PROXXON MS 4 Machine Vice
Use with the drill stand.
PROXXON UHZ Universal Holder
Keep your tool stationary whilst you maneuver what you are working on.
PROXXON Router Base OFV
For slotting, milling grooves and milling edges.
A very precise and accurate heavy duty mini-tool drill with an aluminium motor casing and variable speed (5,000-20,000rpm) suited to professional use in the workshop. Perfect for jewellers, model builders, mechanics, artists and electronics enthusiasts. Can be used for prolonged periods for drilling, grinding, polishing, cleaning and engraving. The high speed 100W motor has full-wave electronic speed control and is low in noise. The aluminium casing dramatically reduces any potential bearing problems resulting in an exceptionally smooth and vibration free tool. Please note that this unit will not accept a keyless chuck.
Supplied in a carrying case with 30 accessories and full set of six collets from 0.8mm to 3.2mm.
4.20 26
