PROXXON PF 250/BL Mill/Drill Head
109489
From £779.28 £649.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Turn a PD 250/E or PD400 lathe into a mill/drill
  • T-Slotted compound table with 110 x 70mm travel
  • Variable speed and tilting head
  • Includes column, mounting bracket and bolts
  • Supplied with 6, 8 & 10mm ER16 collets
The milling PF 250/BL is designed and built for milling and drilling on a PROXXON PD 250/E or PD 400 lathe. Both of which are already drilled accept this mill/drill head. The mill/drill’s table replaces the lathe's top slide, thus adding a compound table, with X-Y travel being longitudinally and cross-wise respectively of 110 x 70mm, with 3 T-slots. The millhead tilts up to 90° left and right. Speed can be pre-selected from 400 - 6,000rpm, the head features a digital speed indication. Speed sensors guarantee high torque also in the lower speed range. The tool holder uses ER 16 collets, the PF 250/BL is supplied with 6mm, 8mm and 10mm collets.
A rotational speed chart on the front of the housing shows the appropriate spindle speeds for the most common applications.
Warranty PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
