PROXXON SLIM-line VDE Screwdriver - SL/PZ2
107384
From £5.98 £4.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • Special SL/PZ2 tip for combination head terminal screws
  • SLIM-line 100mm blade for better access to recessed screws
  • Safe for working on live parts up to 1,000V
This VDE insulated FLEX-DOT screwdriver features a SLIM-line blade offering greater access to recessed terminal screws. The tip is SL/PZ for an exact fit in the heads of combination screws (slotted/pozidriv) frequently used in electrical installation, e.g. in switch cabinets, fuse boxes and terminal blocks.
Insulated VDE screwdrivers for safe work on or around live parts up to 1,000V AC voltage. The protective insulation is directly moulded onto the screwdriver blade. Each screwdriver is individually tested and inspected.
Blade length 100mm, tip SL/PZ2.
