PROXXON FLEX-DOT Slotted Screwdrivers
- Ergonomic design for ease of use
- FLEX-DOT technology for comfortable continuous use
- Oil and acid resistant handle
PROXXON screwdrivers have an ergonomic design which, allows for excellent handling and ease of use. The handle is made up of two components and has the ‘FLEX-DOT’ nubs for comfortable continuous use. The handle is also oil and acid resistant and is made up of a non-stick rubber. These screwdrivers have a processed black tip giving you greater precision for accepting screws and eliminate the tool from slipping.
