PROXXON Splash Guard & Chip Collecting Tray for PD 400
474357
From £250.18 £208.48
1 Review
Out of Stock
  • Made from 1.25mm steel plate, powder coated
  • Slopes on the front and rear make it easy to clean
  • 800mm long x 270mm wide x 290mm high
Made from 1.25mm steel plate, powder coated. Cooling fluid and chips are collected by the tray. A welded cover protects the lathe motor. Slopes on the front and rear of the tray make it easy to clean. Mounting holes and raised base to secure the PD 400 are pre-drilled. Seeping through of coolant is impossible. Size: 800mm length x 270mm width x 290mm height.
5.00 1
