PROXXON TB 50 Table Belt Sander - 230V
109494
From £399.98 £333.32
1 Review
In Stock - Ready to dispatch
  • Benchtop belt sander for modelling and fine craftwork
  • Belt tilts from 0° to 90°; vertical through to horizontal
  • Mitre fence included for accurate angle sanding
  • Strong die-cast aluminium table (210mm x 145mm)
  • Belt size 50 x 533mm
Everything you want from a stationary belt sander in a small precise form with extra versatility. It is ideal for fine sanding work and the most minute corrections on soft and hard woods, non-ferrous metals, steel, plastics (perspex and PC cards) and cork.
Sands long edges, end sections, radii, mitres, and, by turning the workpiece over it also accurate works flat surfaces at right angles. The sturdy plane-milled die-cast aluminium table is 210 x 145mm, offering plenty of support for small work pieces. The table has a mitre slot for the mitre fence allowing you to sand at exact angles. A scale with and a locking knob enables you to angle the belt from 0° to 90°, allowing you to use the belt vertically or flat and anywhere in between. When used flat the mitre fence becomes a stop.
The TB50 is powered by a balanced DC-motor with a no-volt release switch. The belts are 50 x 533mm and run at 400m/min for fast and highly effective sanding. Belt changes are easy thanks to the spring loaded rollers, which also feature fine adjustment for belt tracking. The well designed dust hood is highly effective when connected to a suitable vacuum for extraction.
The compact design means you can stow the TB50 easily after its work is done.
Replacement belts available in sizes;
100g (SKU 109970)
180g (SKU 109971)
240g (SKU 109972)
Warranty PROXXON Micromot: 2 year warranty for private use, 1 year warranty for commercial use
5.00 1
