Restore Rust Remover - 250ml
211833
From £17.48 £14.57
  5. Half Star
14 Reviews
  • Buy 10 for £15.73 £13.11 each
  • Buy 25 for £14.86 £12.38 each
  • Buy 50 for £13.99 £11.66 each
In Stock - Ready to dispatch
  • Restore rusty steel and iron components and tools
  • Water-based, removes the rust and protects against further corrosion
  • Biodegradable and non-toxic, dilute up to 20:1
Restore rusty steel and iron components and tools. Non-acidic, water-based formula only removes the rust and is harmless to plastics, rubbers, and non-ferrous metals. It protects against further corrosion. Dilute up to 20:1 using a polythene or stainless steel container as a de-rusting bath. Degrease the item first, using Restore pre-clean degreaser (available separately), remove loose rust then suspend it in the bath. Once clear of rust rinse clean and dry.
4.30 14
