Rider 4 Piece Cabinet Scraper Set
107525
107525
- 50 x 150 x 0.4mm & 0.6mm for fine work
- 60 x 150 x 0.8 & 1mm for heavier stock
- Supplied in a rust preventative cortex bag
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
Cabinet scrapers are a most underrated tool and hugely useful. This set of four spring steel rectangular cabinet scrapers has all the answers for general work. It comprises two 150mm x 50mm one 0.4mm and the other 0.6mm thick. The two larger thicker cabinet scrapers are 150mm x 60mm, at 0.8mm and 1mm thick. They are supplied in a cortex rust protective bag. The different thicknesses give you plenty of options from heavier work with the thickest, such as removing glue to fine work with the thinnest like careful finishing of tricky grain.
#AxminsterTools
