Robust Scout Woodturning Lathe
108309
From £6,199.98 £5,166.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • IMPORTANT: Please contact Axminster Tools to arrange a more detailed explanation of the Robust Scout Woodturning Lathe and the options available to suit your individual needs. Please call 03332 406 406 to speak with our specialist sales team to arrange the consultation or fill in the enquiry form further down the page. This machine is delivered by our own Axminster transport team.
  • An incredibly well built benchtop lathe
  • Stainless steel bed ways, 660mm between centres
  • Variable speed with digital readout and reverse
The Scout
An excellent mid-sized benchtop lathe for turners who want a compact and powerful performance.
  • 1HP motor as standard (110 or 220 volt)
  • 355mm over the bed and 660mm between centres
  • Optional Robust Universal Stand available
  • Digital RPM readout and 24-position indexing
  • Stop bar function enables a quick stop when hands are full
  • Robust’s seven year 'head to tail' warranty as standard, which includes headstock bearings
Explore full upgrade options
Fully customise your lathe with additional features to suit your turning needs, and build your dream lathe today.
Motor Upgrade
Take on bigger projects with more power, upgrade your motor to 1.5HP.
Steady Rest
Prevent vibration when turning long and thin projects between centres and ensure accuracy.
16" Bed Extension
Increase your turning capacity by an extra 406mm.
Universal Stand
Available for Scout only, adjust the height and even tilt your lathe - can be used for seated woodturning. A castor kit is available for this stand.
Remote Foot ‘Off’ Switch
A useful safety feature when your hands are full. Simply turn off the lathe using your foot. Note this is an ‘off’ switch only.
Choose the features you want the most to suit your turning needs, and build your dream lathe today.
Enquire now
When it comes to the comparing bench top lathes, the Robust Scout must come top of the list. The design and build quality are second to none. Robust Scout is one solid, well built benchtop lathe.
To begin with you get stainless steel bed ways on a rigid fabricated steel bed. A 1.1kw motor and inverter offer dial controlled variable speed (50-3,000rpm), with digital readout and reverse. The single pulley design means plenty of torque, without fiddly belt changes. The spindle lock disconnects the controls preventing accidental start-up. Another great safety feature is the stop bar, running the full length of the lathe bed. With both hands holding a tool, a quick nudge with your hip stops the lathe. The headstock has a 24-hole index with each stop lockable with a pin. The tailstock quill has 75mm of smooth travel for boring.
Overall the Scout is a lot of lathe. If proof were needed of the quality, the 7-year warranty proves the faith that Robust have in their products.
Optional accessories include a bed extension, increasing the standard 660mm between centres to 1,065mm, and the unique universal stand, which is adjustable in height and can even be configured to allow you to turn whilst seated.
N.B. As lathes will be made to order, a 15% non-refundable deposit will be required. Additional information will be given by our specialist sales advisor upon enquiry.
Warranty 7 Year Warranty
