The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe and Newcastle stores.
High quality European made machine, built to last.
1ph or 3ph motor with additional options available
Contact our Business Team to discuss your requirements
600mm disc with tilting cast iron table
Fine angle adjustment for finishing to precise angles
Mitre gauge with +/- 60° adjustment for compound angles
With a large diameter sanding disc yet relatively small footprint, the CB600/1 Disc Sander is a dependable machine that can finish to precise angles with ease.
Fine ground cast iron table
The CB600/1 has a generous 700mm x 300mm table built from heavy cast iron, complete with a scale to finish to precise angles.
Suitable for sanding a range of materials
Designed to be used with wood, aluminium alloys and all types of plastic, the CB600/1 is a truly versatile sander.
Easily adjustable table
A useful feature; the table tilting mechanism allows fine angle adjustment to achieve an accurate angle for your table.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years experience in the industry, the ROJEK name is synonymous with high quality machinery. See the full range
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient. Find out more
The ROJEK CB 600/1 Disc Sander is a rugged, and dependable floor standing machine. With its large 600mm diameter sanding disc the CB 600/1 removes material with ease for all fitting and finishing operations. The heavy cast iron table features a tilting mechanism with fine angle adjustment and scale for finishing to precise angles. This type of machine is particularly suited to tasks where accuracy is paramount. The table is a generous 700mm wide and 300mm deep and tilts from 0° to 45° providing plenty of capacity for a variety of tasks. A mitre gauge with +/- 60° adjustment is included allowing sanding of compound angles. The table swings to one side to allow easy access for changing the sanding disc.
The sander is fitted with a 100mm diameter dust extraction outlet and a brake. The machine has a relatively small footprint, allowing it to be accommodated in virtually any workshop, even where space is at a premium.
The CB 600/1 is a high quality European made machine, built to last.
The CB 600/1 is available with a single phase or a three phase motor and with a variety of additional options. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
