With a large diameter sanding disc yet relatively small footprint, the CB600/1 Disc Sander is a dependable machine that can finish to precise angles with ease.
Fine ground cast iron table
The CB600/1 has a generous 700mm x 300mm table built from heavy cast iron, complete with a scale to finish to precise angles.
Suitable for sanding a range of materials
Designed to be used with wood, aluminium alloys and all types of plastic, the CB600/1 is a truly versatile sander.
Easily adjustable table
A useful feature; the table tilting mechanism allows fine angle adjustment to achieve an accurate angle for your table.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years experience in the industry, the ROJEK name is synonymous with high quality machinery. See the full range
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient. Find out more
The ROJEK CB 600/1 Disc Sander is a rugged and dependable floor standing machine. With its large 600mm diameter sanding disc the CB 600/1 removes material with ease for all fitting and finishing operations. The heavy cast iron table features a tilting mechanism with fine angle adjustment and scale for finishing to precise angles. This type of machine is particularly suited to tasks where accuracy is paramount. The table is a generous 700mm wide and 300mm deep and tilts from 0° to 45° providing plenty of capacity for a variety of tasks. A mitre gauge with +/- 60° adjustment is included allowing sanding of compound angles. The table swings to one side to allow easy access for changing the sanding disc.
The sander is fitted with a 100mm diameter dust extraction outlet and a brake. The machine has a relatively small footprint, allowing it to be accommodated in virtually any workshop, even where space is at a premium. This ready to buy machine package comes supplied with a 1ph motor.
The CB 600/1 is a high quality European made machine, built to last, and designed to be dependable with the industry user in mind. Our specialist consultants will be happy to discuss the ROJEK range with you; email sales@axminstertools.com or call 03332 406406. This machine can be viewed in person at our High Wycombe and Newcastle stores.
