The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe and Newcastle stores.
High quality European made machine, built to last.
Available 1ph or 3ph and additional options
Contact our Business Team to discuss your requirements
Built to last and dependable, the FSN300A comes with a tilting spindle and four speeds as standard - and a generous range of optional accessories to enhance the usefulness of the machine even further as required.
Precision ground cast iron table
Workpieces will glide over the cast iron table, which is precision ground for accuracy and longevity.
Aluminium sliding table
The 1200mm aluminium sliding table is precision mounted on chrome-vanadium 360T steel bars for ultra smooth gliding.
Tilting spindle, four speeds
Easily lock the 30mm diameter spindle at any angle between -5° to +45°. The spindle mounting is in a robust cast iron body to ensure accuracy and reliability. Thanks to an impressive speed range, a variety of tooling can be used; from small blocks to larger panel fielding cutters up to 200mm diameter.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years experience in the industry, the ROJEK name is synonymous with high quality machinery. See the full range
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient. Find out more
The FSN 300A spindle moulder is well suited to the professional workshop. It features a cast iron bed, precision ground, for both accuracy and longevity. This is a reliable and solidly built machine.
Even in its basic form it comes with a tilting spindle, a choice of four speeds and a precise 1,200mm sliding table running on round CV 360T steel bars. The 30mm diameter spindle can be tilted and locked at any angle from -5° to +45°. The speed range allows different tooling to be used, from small blocks to larger panel fielding cutters up to 200mm diameter.
A wide range of optional accessories offer the opportunity to tailor the machine to particular needs as well as the potential to enhance the usefulness of the machine in the future.
Optional accessories include: - Cross Cutting Frame, Right & Left Extension Tables, Wheel Kit, Support Table, Tenoning Table, Tenoning Guard, Ring Fence, Router Collet Chuck, and Router Interchangeable Spindle.
The FSN 300A is a high quality European made machine, built to last. The FSN 300A is available with either 240V single or 415V three phase motors and with a larger sliding table. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
