The FSN 300A Spindle Moulder is well suited to the professional workshop. It features a cast iron bed, precision ground, for both accuracy and longevity. This is a reliable and solidly built machine.
This machine comes with a tilting spindle, a choice of four speeds and a precise 1,200mm sliding table running on round CV 360T steel bars. The 30mm diameter spindle can be tilted and locked at any angle from -5° to +45°. The speed range allows different tooling to be used, from small blocks to larger panel fielding cutters up to 200mm diameter. This ready to buy machine package comes supplied with a 1ph motor.
There are a range of optional accessories to tailor the machine to your particular needs. These include: Cross Cutting Frame, Right & Left Extension Tables, Wheel Kit, Support Table, Tenoning Table, Tenoning Guard, Ring Fence, Router Collet Chuck, and Router Interchangeable Spindle.
The FSN 300A is a high quality European made machine, built to last and designed with the industry user in mind. Our specialist consultants will be happy to discuss the ROJEK range with you; email sales@axminstertools.com or call 03332 406406. This machine can be viewed in person at our High Wycombe and Newcastle stores.
