The MP 415 thicknesser is designed and built for a busy professional workshop. This machine has all the capabilities and capacities required in a modern joinery workshop. The MP 415 thicknesser is fitted with the latest technology but built in the solid cast iron tradition. This machine will give years of service. Having a separate thicknesser speeds up production. The MP 415 can handle a wide variety of work, producing accurate results time after time. It features a precision ground cast iron table with a large central column support.
This ready to buy package includes a spiral cutter block, which offers numerous advantages; notably quieter in use, the sheer cutting action of the spiral block also produces a super smooth finish with no visible lines across the board. Fitted with 3 spirals and 66 knives, the spiral block features 56 15mm solid tungsten cutters in a helical pattern. Lasting ten times longer than HSS, when the edge of the square tungsten cutter dulls, it can be rotated to a fresh and sharp edge, removing the need for complicated knife changes. By producing smaller chips, strain on the machine is reduced and extraction is more efficient.
The MP 415 is a high quality European made machine, built to last. Our specialist consultants will be happy to discuss the ROJEK range with you; email sales@axminstertools.com or call 03332 406406.
