The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our Cardiff, High Wycombe and Newcastle stores.
High quality European made machine, built to last.
Choice of cutter blocks, HSS, Tersa or Spiral
Contact our Business Team to discuss your requirements
Get years of service from this solid and precise machine - ideal for a busy professional workshop.
Fine ground cast iron tables
Timber will pass smoothly over this 1500mm fine ground cast iron table. The cast iron reduces vibration and will ensure flatness and accuracy even with demanding use.
Single lift tables
Save time and effort thanks to the single lift tables, aided by large hinges with torsion springs. Easily switch from planing to thicknessing; plus, get set up quickly and easily as the fence can stay in place.
Cast iron fence with aluminium fence plate
Timber is easily squared with this durable and robust cast iron fence, which tilts 90⁰-45⁰.
Tersa or spiral cutter blocks
Tailor to your needs with either a four-knife block with re-sharpenable HSS knives, a three-knife Tersa block for quick changes with no extra set up, or the latest spiral cutter block for a clean finish and reduced sanding time.
Generous capacity
The MSP 315 has a thicknessing capacity of 300mm x 230mm and a 310mm planing width, making this machine hugely useful within a professional workshop environment.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years of experience in the industry, the ROJEK name is synonymous with high quality machinery.
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient.
The ROJEK Euro 9 MSP 315 is an industrial planer thicknesser with single lift cast iron tables. Large hinges with torsion springs make it easy to handle the cast iron tables when changing from one function to the other. It has a generous 310mm planing width and a 300 x 230mm thicknessing capacity.
The MSP 315 is built around solid, precision ground cast iron tables. This machine is ideal for a modern and busy professional workshop and will give years of service.
The MSP 315 is available with either a four-knife block with resharpenable HSS knives, a three-knife Tersa block for easy changes or the latest spiral cutter block. Other options such as additional rollers, morticing attachment and a wheel kit are available to tailor the machine to particular need or requirements.
The MSP 315 is a high quality European made machine, built to last. The MSP 315 is available with either 240V single or 415V three phase motors. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
