The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our Cardiff store.
Well designed big capacity panel saw with cast iron table
High quality European made machine, built to last
Available in 1ph or 3ph and with many additional options
The PK320A Panel Saw is a well-designed machine perfectly suited to a smaller-scale production workshop, offering reliability and ease of use.
Fine ground cast iron table
Enjoy a superior experience with this fine ground cast iron table. The cast iron reduces vibration and will ensure flatness and accuracy even with demanding use.
Heavy duty sliding table
Sliding tables are available from 2m - 3.2m, which come precisely mounted on chrome-vanadium steel bars for ultra smooth gliding.
Separate scoring blade motor
The main motor and scoring blade motor are mounted on a robust cast iron trunnion. With a separate motor driving the scoring blade, the main blade maintains full power for a consistent cut.
European made
From their production plant in the Czech Republic, ROJEK is a major global manufacturer. With over 100 years experience in the industry, the ROJEK name is synonymous with high quality machinery. See the full range
Thought about leasing?
There is a range of finance options to make investing in machinery simple, affordable, and tax efficient. Find out more
The PK320A Panel Saw is a large capacity machine. It offers any demanding professional workshop a high degree of accuracy coupled with ease of use and reliability. Separate motors drive the main blade and the scoring blade. The motors, the rise and fall and tilt mechanisms are mounted in a robust cast iron housing guaranteeing solidity with smooth and precise adjustments. The PK320A comes fitted with a very well designed sliding table. The sliding table is mounted on round chrome-vanadium steel bars and runs exceptionally smoothly.
The PK320A is a high quality European made machine, built to last. The PK320A is available with either 240V single or 415V three phase motors. Other options are available to tailor the machine to particular needs and requirements.
Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
