The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe and Newcastle stores.
High quality European made machine, built to last
Contact our Business Team to discuss your requirements
The design of the PK315A perfectly reflects ROJEK's commitment to quality and innovation. This machine includes many useful features generally only to be found on larger (more expensive) panel saws. The PK315A is amongst the best in its class with a rigid construction and ground cast iron table, guaranteeing a long service life. This European made machine offers any demanding professional workshop a high degree of accuracy coupled with ease of use and reliability.
Standard equipment includes a very precise sliding table mounted on round chrome-vanadium steel bars for a super smooth operation. The large panel support is supported by a telescopic arm for rigidity exactly where needed. The panel support frame can take 2,400 x 1,200mm sheet material and includes a crosscut mitre fence, two flip stops and a cam operated clamp. The solid rip fence offers up to 800mm ripping width. The PK315A features a scoring saw with a separate 0.75kw motor for super clean cuts in faced boards. The main saw blade is 315mm, but the saw will take a larger diameter 350mm blade for increased depth of cut if required.
Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
