The high standard of engineering and manufacturing make this spindle moulder one of the best in its class. It is well suited to small to medium sized professional joinery shops. The Industry 9 series machines are designed for hard, daily use. The FSN 550A is built with a precision ground cast iron table.
The FS 550A comes with a tilting spindle, a choice of four speeds and a precise 1,200mm sliding table running on round CV 360T steel bars. The 30mm diameter spindle can be tilted and locked at any angle from -5° to +45°. The speed range allows different tooling to be used, from small blocks to larger panel fielding cutters up to 250mm diameter. This spindle moulder package includes two valuable additions: a cross cutting frame with fence, to aid in the handling of larger panels; and a modification to allow the use of interchangeable spindles instead of a fixed spindle. This enables a quick set up, as you can interchange spindles with tooling already set up.
There is a further range of accessories available to tailor the machine to your particular needs and requirements. These include: RH & LH Table Extensions, Tenoning Table, Tenoning Hood, Ring Fence, Outrigger Roller, Electronic Spindle Height Adjustment, 30mm Extra Interchangeable Spindle and a 30mm Collet Chuck Interchangeable Spindle for router cutters.
The FS 550A is a high quality European made machine, built to last and designed with the industry user in mind. Our specialist consultants will be happy to discuss the ROJEK range with you; email sales@axminstertools.com or call 03332 406406. This machine can be viewed in person at our High Wycombe store.
