ROJEK Industry 9 PF 350 3200mm Panel Saw
109119
From £8,774.98 £7,312.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
  • High quality European made industrial machine
  • Available in 1ph or 3ph and with many additional options
  • Contact our Business Team to discuss your requirements
  • Quality engineering, design and manufacturing
  • 350mm diameter blade, 115mm depth of cut
  • 3,200 sliding table with telescopic cross cutting fence
  • Scoring blade for splinter-free cuts
The Industry 9 series machines from ROJEK are designed for hard, daily use. The high standard of engineering, design and materials make this panel saw an excellent choice for a professional joinery shop. The PF 350 is built with a precision ground cast iron table. It takes a 350mm diameter saw blade giving a depth of cut of 115mm (80mm@45). The basic model comes fitted with a 3,200mm sliding table allowing large sheet materials to be cut to size with ease. The scoring blade with its separate motor ensures a clean splinter-free cut every time.
Standard Equipment includes :-
Aluminium sliding table 360 x 3200mm on steel round bars, Mitre fence with protractor +45°/-45°, Rip fence with micro adjustment, Ripping stop, Handle of sliding table, Blade safety guard, Scoring unit with separate motor, Cam operated panel clamp.
A wide range of optional accessories offer the opportunity to tailor the machine to particular needs as well as the potential to enhance the usefulness of the machine in the future.
Optional accessories include: -
Digital indication of rip fence position, Digital indication of cross-cut stop, Outrigger roller, Table extension – width of cut 1500mm, Precise angle adjustment 5°,10°, 15°, 20°, 22,5°, 30°, 40°, 45° (for cross-cutting fence), Additional second outrigger with support leg, Upper control panel, Upper control panel with electric saw blade tilting and uplift – ELGO, Electric saw blade tilting and uplift – ELGO, Supporting profile of the frame, Variable speed of saw blade; inverter (with motor 10,2HP).
The PF 350 is a high quality European made machine, built to last. Contact our Business Team to discuss your requirements; call 03332 406406 or email sales@axminstertools.com.
Warranty 1 Year Warranty
